PreviousNext
JavaScript must be enabled to correctly display this content
Checking Owning User Account Using SQL
You can use SQL to check the owning user information.
To find the owning user of the DCF, enter this SQL query:
select owning_user from data_clarification_forms where dcf_id=xxxxx;
If the owning_user query in the above step returns a value, execute this query, substituting the value for returned_value, to check if the owning user has an Oracle user account:
select count(*) from oracle_accounts oa where ORACLE_ACCOUNT_NAME='returned_value';
If the count is zero, the owning user does not have an account.
From the Admin menu, select Users, then select Oracle Accounts, and add the account.
