Troubleshooting: Unable to Print DCF
If you are unable to print a DCF Report, check the following:
If you are printing a DRAFT or FINAL DCF, you must enter a value for New DCF Status to Assign parameter.
If a FINAL report has been printed, the DCF print status must be REPRINT or COPY. Otherwise the DCF print status must be DRAFT or FINAL. You can tell if a FINAL report has been printed by clicking the DCF Pages button. If there are any pages listed, a FINAL report has been printed.
The DCF owning user may not be entered in Oracle Accounts. To check this, use one of the methods below:
