Description of Fields
This section contains brief descriptions of the fields of the Maintain Data Clarification Forms utility.
Table 5-1 Fields in the Maintain DCFs Window
| Field | Description |
DCF Number |
The unique identifier assigned by the system to the DCF record. |
Status |
The DCF's current state in the review process. Click F9 for a list of values. The system assigns a status of CREATED to new DCFs. The default statuses are: Created, Draft, Final, Sent, Received, Reviewed, Closed. You can set the status in the Maintain DCFs window and when you print the DCF Report. After the DCF Report has been sent, the system also sets the DCF status based on the status of its DCF Pages. DCFs also have a Print Status, which is different. See Tracking DCF Pages, Changing the DCF Status from the Maintain DCFs Window and DCF Print Status. You can change statuses and make them optional in the Installation reference codelists DCF STATUS CODES and DCF OPTIONAL STATUS CODES. |
Description |
Free text description of the DCF. The creator of the DCF supplies this value. If you have the necessary privileges, you can modify this value. |
Patient |
Unique identifier of the patient position. DCFs include discrepancies associated with only one patient's data. |
Investigator |
The code and name of the Investigator. If a single Investigator was specified for the DCF, all of the discrepancies on this DCF are specific to this Investigator. |
Site |
Name of the site. If a single site was specified for the DCF, all of the discrepancies on this DCF are specific to this site. |
Owning User |
The person responsible for the DCF. The default is the user who logs the DCF. |
These fields are available by clicking the Details button:
Table 5-2
Distribution Status |
This field is set when the DCF is created and identifies the review status of discrepancies to include on the DCF report. |
Non-Distribution Status |
This field is set when the DCF is created and identifies the review status of discrepancies to withhold from the DCF report. |
Resolved Status |
This field is set when the DCF is created and identifies the resolution status of discrepancies to include in this DCF. This allows a DCF report to be generated that contains only discrepancies that have been resolved internally, and are being forwarded to the Investigator for confirmation. |
Selection Criteria |
This field contains ranges that were applied when the DCF was created. If the DCF was created from the Discrepancy window using a Group Function, this field is set to "Multi Select". |
Printed Last |
Timestamp of the last print action. This field is populated for all Print Status codes. |
Printed By |
Use the name of the last print action. This field is populated for all Print Status codes. |
Parent topic: Using Data Clarification Forms
