Calculating DCI and Interval Expectedness for Patients
In order to accurately reflect which DCIs and Intervals are expected for each patient in real time in RDC Onsite data entry, Oracle Clinical automatically recalculates expectedness in almost every situation where it might change for a patient.
There are just a few situations in which you should run the job manually.
For more information, see:
- Automatic Expectedness Calculation for Patients
- When and How to Run Expectedness Calculation Manually
Parent topic: Defining DCI Books
In this section:
Parent topic: Calculating DCI and Interval Expectedness for Patients
Automatic Incremental Expectedness Calculation
The incremental mode of the expectedness calculation job is sufficient for updating expectedness due to changes in patient data. It begins at the patient's earliest CPE with data changes that might impact expectedness—that is, data entered for a Question or DCM that is defined as a rule trigger.
The system automatically runs incremental expectedness processing during Manual Data Entry and Batch Data Load and Batch Data Delete.
Manual Data Entry - The system automatically runs incremental expectedness calculation during data entry in Oracle Clinical and RDC, updating the expectedness of DCIs and Intervals for the patient if required. This occurs when the user saves data.
In RDC it occurs at every data entry transaction and, if the patient requires recalculation, as soon as a user opens a CRF for a patient.
Batch Data Load and Batch Data Delete - For Batch Data Load and Batch Data Delete, the system performs the expectedness calculation immediately after completing the main transactions to minimize locking time. Each patient with modified data is processed by a separate transaction.
Other Types of Data Changes - The system also recalculates expectedness as follows:
Mass Changes: Every Received DCI is a single transaction which includes the immediate expectedness calculation, if needed.
Patient Transfers: All changes for a single Patient transfer are performed as part of the transfer transaction, including the processing of multiple patients in an ongoing transfer.
Derivation Procedures: Oracle Clinical processes the changes for each Received DCI as a transaction. The expectedness calculation is performed as part of these transactions if the Derivation Procedure derives a trigger Question. This applies whether the Derivation Procedures are run in Batch Validation, Execute Single Procedures, or as Online procedures from RDC.
Parent topic: Automatic Expectedness Calculation for Patients
Automatic Full Expectedness Calculation
Full expectedness calculation performs a complete recalculation of expectedness, beginning at the patient's first CPE and discarding all previous results. The system uses it when a patient is assigned or reassigned to a DCI_Book.
Full mode is required and automatically run as follows:
Immediately after a user assigns or reassigns patients to a DCI Book using the user interface
At the end of batch validation in production mode, if batch validation detects patient book assignment changes made using a Validation or Derivation procedure. In addition, any Full processing that may have been left incomplete due to a system failure is detected and processed.
At the end of an online Procedure execution that detects patient book assignment changes
During the first data entry transaction (including opening a CRF in the RDC Surround) for any patient marked as requiring expectedness recalculation
Expectedness calculation is not run automatically in the following situations:
For test mode patients after their assigned DCI Book is successfully revalidated, because this may happen many times in test mode during DCI Book definition
Following a batch validation in test mode, even if patient book assignments have been changed
In production mode, when an active DCI Book has been made Provisional and then reactivated
When a patient was assigned to a different Book while "frozen" and is subsequently unfrozen
You may want to run expectedness calculation manually in these situations.
In this section:
When to Run Expectedness Calculation Manually
Because the system runs expectedness calculation automatically each time patient data is updated and after patient book assignment changes, there are very few situations in which you need to explicitly calculate expectedness. They are:
After activating an enhanced DCI Book that has patients assigned
After "unfreezing" patients whose assigned book was activated while they were frozen
After making an existing study flexible in the Clinical Study States window: you must then set any active books to Provisional and reactivate them, and then run Calc Expectedness in Test for all patients and all books. (If a nonflexible study has production data you cannot make the study flexible.)
In addition, if there is a system failure during a batch data load or batch data delete, expectedness calculation may not have completed. You may want to run the job manually. If you do not run the job manually, and if the book is valid, the system will run the job automatically for each patient during the next data entry transaction for the patient or the next batch validation.
Run Calc Expectedness in Test or Prod in the same situations for an Enhanced DCI Book with no rules defined as you would for a Book with rules to ensure that the correct CRFs are displayed for patients in RDC Onsite.
Parent topic: When and How to Run Expectedness Calculation Manually
The test and production modes of the job are available as follows:
The test mode option is available if the DCI Book has a status of Active or a status of Provisional and a validation status of Warning or Success.
The production mode option is available only if the DCI Book has a status of Active.
To run the job:
When the job finishes, a message appears saying whether or not the calculation job has run successfully.
