Creating a Clinical Study
The Maintain Clinical Studies window is the starting point for creating a new clinical study. This window names and describes a clinical study, consolidating many of its details. You can create the new clinical study provided projects, organization units, and regions already exist in Oracle Clinical's Planning subsystem. You can also augment the details of a clinical study originating in the Easy Study Design facility.
Follow these instructions to create a new clinical study:
- Maintaining Clinical Study Objectives
- Maintaining Enrollment Criteria
- Maintaining Study Termination Criteria
- Creating Clinical Study Comments
- Assigning Clinical Study Regions
- Maintaining a Clinical Study's Historical Events
- Reviewing Planning Details
- Updating Clinical Study Statuses
- Deleting a Clinical Study
Parent topic: Planning and Designing a Study
In the Maintain Clinical Study Objectives window, you can create, update, or delete descriptions of clinical study objectives. A study can have any number of objectives. The study can have more than one objective for an objective type. The system automatically queries the objectives for the selected clinical study when you open the window.
Select an objective to work with or use the Insert Record function to add an objective.
Choose the objective's type. You must choose the type of objective from values set in the OBJECTIVE TYPE CODE codelist.
If you have more than one objective for a type, you can rank their importance by assigning them numbers in the Order field.
Select the Final Analysis? field if the objective should be taken into account during the study's final analysis. Leave it deselected if the objective is for interim analysis.
Describe the objective.
Parent topic: Creating a Clinical Study
Use the Maintain Enrollment Criteria window to create, update, or delete the enrollment criteria of participants in a study.
A clinical study can have any number of enrollment criteria. Use the multi-record window to view all the enrollment criteria already assigned to a study. The single-record window contains more complete names for the fields. In multi-record mode, the system sorts the list by the criteria flagged as inclusion criteria first.
To create, update, or delete the enrollment criteria:
- From the Design menu, select Studies, then select Clinical Studies, and click the Termination button.
- Select a termination criterion to work with, or use the Insert Record function to add one.
- Describe the conditions that constitute an early termination.
- Select the Early Term? box (Is Criteria for Early Termination?, in the single-record window), if the termination criterion disqualifies a terminated patient's data from being part of the study's final analysis. Leave the field deselected if an early termination does not remove any of the patient's collected data from final analysis.
- Select the Incl In Safety? (Include in Safety Analysis?, in the single-record window), box if the termination criterion disqualifies an early-termination patient's data from being included in the study's safety analysis. Leave this field deselected if an early termination does not remove any of the patient's data from the safety analysis.
- Select the Incl In Efficacy? (Include in Efficacy Analysis?, in the single-record window), box if the termination criterion disqualifies an early-termination patient's data from being included in the study's efficacy analysis. Leave this field unchecked if an early termination does not remove any of the patient's data from the efficacy analysis.
- Choose any factors to measure in the termination criterion. Designers with randomization privileges can set the code values for factors in the Maintain Factors window (from the Design menu, select Strata, then choose Factors). Set minimum and maximum values to factors that are part of a range (type R). Set a single value for a single-value factor (type V).
A study can have any number of comments, and the system displays all comments for a study after you select it. You cannot update or delete a study comment. From the Design menu, select Studies, then choose Clinical Studies, and click the Comment button. Use the Insert Record function to add a comment. Create comments to record information that have no specific attributes. The system does not use the comments.
You can assign the regions to a study in this window. Study planners can create the values for regions in the Maintain Regions window (from the Plan menu, select Regions), or, from the Design menu, select Studies, choose Clinical Studies, and then click the Region button. The regions display by region code sequence. You can assign a region to a particular clinical study only once; however, a study can be conducted in more than one region and be expanded to include other regions than originally designated.
To maintain the regions for a clinical study, follow these steps:
- Choose an assigned region, or use the Insert Record data function to add a new region.
- Select the Regulatory? box if you include a region for regulatory reasons.
- Select the Marketing? box if you include a region for marketing reasons.
- Select the Reporting? box if this region is the region that appears in reports. Only one region can be the reporting region for a study.
Historical events may be one of two kinds: event recording triggered by the system, or a user-defined event. Historical events triggered by the system include:
Creation of this study
Creation of a study version
Setting or changing the randomization access codes for a study
Setting or changing the randomization access codes for a study phase
Setting or changing the study status
Setting the live study flag
Examples of possible user-defined historical events are producing a first draft of a study, or sending a first draft to another location for review. You can create or display clinical study history records, but you cannot delete or change a history entry. You can record dates for events you expect to occur in the future. The system populates the Type field, assigning user-generated records the value USERDEF.
To create or maintain historical event information, from the Design menu, select Studies, then select Clinical Studies, and click the History button.
Open this window to display planning data about a clinical study. From the Design menu, select Studies, then select Clinical Studies, and click the Planning button. These details are all set in the Planning subsystem. The system sorts and displays phases in chronological sequence.
The buttons along the bottom of this window open several Design utilities. The following section describes these utilities and some of the main fields.
Set the study status to classify the study according to its developmental maturity. The timestamp for each change in status appears in the study's history. Use the list function to set a study's status. Your company maintains study status values on the STUDY STATUS TYPE CODE codelist (from the Admin menu, select Reference Codelists, then choose Design Installation Codelists, and query STUDY STATUS CODE LIST). You can also set randomization access in this window.
The information you enter provides a basis for creating clinical study history records.
To update clinical study statuses:
Deleting a clinical study also deletes these elements associated with the study:
enrollment criteria
termination criteria
objectives
history
regions
comments
versions and related records
To delete a clinical study, from the Design menu, select Studies, then select Delete Study. The Delete Clinical Studies window appears with a Clinical Studies window. The system displays all the current studies. Select the study you want to delete and click the Delete button. The clinical study disappears from the listing.
You receive an error message if you attempt to delete a clinical study with existing received DCIs; also, your company might place local safeguards.
