12 Admin Reports
The following Admin Reports are available in Oracle Clinical and can be generated in PDF, HTML, RTF, Text, and Postscript formats:
  • Reference Codelists*
  • Summary Help Topics*
  • Detail Help Topics*
  • Module Components*
  • Messages*
  • Groups and Users*
  • Oracle Account Access*
  • Module Executions
  • Group Account Access
  • Parameter Definitions
  • Saved Parameter Sets
* These reports can also be generated in an Excel-supported format (in addition to PDF, HTML, and RTF formats) when you select XDOREPORT as the Report Type.
To generate an Admin Report in the generically supported output formats, follow the instructions below:
  1. Log in to Oracle Clinical.
  2. From Admin > Admin Reports > select the report that you want to generate.
  3. Select REPORT from the Report Type drop-down. The supported output formats are PDF, HTML, RTF, Text, and Postscript.
  4. Click OK.
  5. Click Submit Job.
To generate the subset of Admin Reports that are available in an Excel-supported format, follow the instructions below:
  3. Select XDOREPORT from the Report Type drop-down. The supported output formats are XLS, PDF, HTML, and RTF.
  4. Click OK.
When Report Type is set to XDOREPORT, the Job Details, Job Status, and Schedule buttons are disabled. Additionally, the resultant Report file generated is named 'getXdoReport' and is downloaded to the browser's default download directory.
