Printing Left Default Prompts for Repeating Response Fields
When you setup and define DCM questions in Oracle Clinical, you can define repeating default values for repeating question groups.
To print left repeat default prompts for each repeating response in a CRF:
  1. Enter the default response prompt when you define the DCM question in a DCM.
  2. Select Left as the prompt position when defining the DCM question group.
    Once defined in Oracle Clinical, RDC automatically includes the default repeat prompts for all defined responses to print (and display) in the DCM question group in the CRF:
    • When you print a Blank Casebook Report
    • When you open a new blank CRF in RDC
