Tools for Configuring Discrepancy Management
You use the reference codelists in Oracle Clinical to define your discrepancy management system for both Oracle Clinical and RDC.
To configure most settings for discrepancy management, you use the installation reference codelists in Oracle Clinical. The settings in the installation reference codelists apply to your entire installation.
To access the installation reference codelists:
  1. Open Oracle Clinical.
  2. Navigate to Admin, Reference Codelists, and then select Installation Codelists.
This chapter assumes you are familiar with querying, modifying, and saving reference codelists. If you need more information on reference codelists, see the Oracle Clinical Administrator's Guide.
