4 Study monitoring
The following tasks describe how to manage ongoing studies. For example, it includes steps to monitor, suspend, and resume study File Watchers. It also describes how to view, cancel, and suspend scheduled jobs. See the following topics for details.
Monitor, suspend, and resume study File Watchers
The study configurator can also suspend and resume File Watchers.
Parent topic: Study monitoring
View file specifications for study File Watchers
If a data file is not loaded as expected, the problem may be that the file is not named as required by the file specification for the study/clinical data model/lifecycle combination. The study configurator creates file specifications.
Monitor validation check discrepancies sent to the source data system
Validation checks with an Initial Action set to Send to System immediately send discrepancies they create to InForm or another source data system as queries. To check the status of this operation:
View, cancel, and suspend scheduled jobs
This pane displays currently scheduled jobs. After a job has been canceled or suspended here or elsewhere, it no longer appears.
The exception is that File Watcher Specifications that are current and not explicitly suspended are still displayed even if they are not running because the corresponding Study File Watcher is suspended. If the Study File Watcher is resumed, these File Watcher Specifications resume.
You cannot reschedule jobs in the Administration page. Do so:
For transformations and validation checks, in the Home page.
For data loads, in the Clinical Data Models page under Study Configuration.
View past and current job executions
Use this page to query for jobs that have already run and jobs that are currently running. You can cancel jobs that are in progress.
Use tracing and logging
Use this page to turn on either logging (debugging) or tracing, either for a particular user or all users. When a user logs in while tracing or logging is running for any user or systemwide, a message appears at the top of every page notifying them that diagnostics are running.
Turn on tracing or logging
Logging and tracing begin for each user when he or she logs in after the request has been made. They begin immediately for your own session.
Parent topic: Use tracing and logging
Locate the trace file
The trace file is generated on the database server. Its location and name are in the TRACEFILE column of the system view V$PROCESS. Use the following query to fetch this and other useful information:
select s.sid,s.serial#,s.audsid,s.username,s.osuser, s.client_identifier, s.sql_trace,s.action, p.spid, p.TRACEFILE from v$session s,v$process p where s.paddr=p.addr and s.username is not null;
The username for nonbatch jobs is CDRRUN and the client_identifier is the DMW username of the user whose session is traced. If tracing is running for a particular user, the trace file identifier is appended to the trace file name just before the .trc extension.
Turn off tracing or logging
When tracing or logging is turned off, the job is no longer displayed in this page.
Truncate logging data
To delete all logging data from the database:
- Click the Navigation icon
at the top of any page and then click Administration. - Click the Tracing and Logging tab.
- Make sure no logging processes are currently running.
- Click the
Truncate Log Data icon.
Set up data visualizations
You can integrate an external data visualization tool so that users can view data graphically and interactively with the protection of DMW security and blinding access privileges, one clinical data model at a time. Requirements:
The study configurator must select the Business Area option when he or she creates or modifies a clinical data model. The system then generates a Business Area object in the database containing views of all tables in the model.
Users viewing DMW data in a visualization tool must have a database account and must log into the visualization tool using the database account.
In hosted releases you must install the visualization tool locally and access your hosted data over your VPN.
