4 Business Areas
- Define and Modify Business Areas
- Create and Modify Business Area Hierarchies
- Create and Modify Business Area Joins
- Public APIs and Naming Views for Generic Visualization Adapter (GVA)
Parent topic: Object APIs
This is a public interface for Business Area-related APIs, including creating, modifying, and removing Business Areas. It also includes APIs for checking Business Areas in and out, and undoing a Business Area checkout.
- Create a Business Area
- Modify a Business Area
- Check Out a Business Area
- Undo a Business Area Checkout
- Check In a Business Area
- Remove a Business Area
Parent topic: Business Areas
Use this API to create a new Business definition, a new instance of an existing Business Area definition, or a new definition and an instance of it.
Name
CDR_PUB_DF_BUSINESSAREA.CreateBusiArea
Signature
PROCEDURE CREATEBUSIAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDRPRGOBJTYPE IN CDR_BUSAREA_OBJ_TYPE, PI_CREATEOBJECT IN VARCHAR2, PI_INSTANCE_SUBTYPE_ID IN CDR_NAMINGS.OBJECT_SUBTYPE_ID%TYPE, PI_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL, PI_INSTCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
If you are creating a new definition only or a new definition and an instance of it, enter values for the new definition.
If you are creating an instance of an existing definition, enter values to identify the definition. For OBJECT_TYPE_RC enter $OBJTYPES$BUSAREA if you are creating a definition only; $OBJTYPES$BUSAREAREF if you are creating an instance of an existing definition; and NULL if you are creating a new definition and an instance of it.
- PI_CDRPRGOBJTYPE (Optional) This is a parameter of table type
CDR_BUSAREA_OBJ_TYPE specific to Business Areas.
If you are creating a new definition, enter values for the new Business Area.
The following attributes are required: ADAPTER_COMPANY_ID,ADAPTER_OBJ_ID,ADAPTER_OBJ_VER.
If you are creating an instance of an existing Business Area, do not enter any values here.
- PI_CREATEOBJECT (Mandatory) Enter DEFN to create a definition only; INST to create a instance of an existing definition; or BOTH to create a new definition and an instance of it.
- PI_INSTANCE_SUBTYPE_ID (Optional) If you are creating a new instance, enter
the ID for the subtype you want to give the instance.
If you are creating a definition only, do not enter a value for this parameter.
- PI_DEFCLASSIFICATIONCOLL (Optional) By default, the new definition is
classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE.
If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID.
If you want the definition to inherit its classifications for a particular level from its parent, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero).
If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Business Areas. Do not enter any values for them.
- PI_INSTCLASSIFICATIONCOLL (Optional) By default, the new instance is
classified according to the subtype you assigned it in the PI_INSTANCE_SUBTYPE_ID.
If you want the instance to inherit its classifications for a particular level from its parent Work Area, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero).
Parent topic: Define and Modify Business Areas
Use this API to modify a Business Area definition or instance.
If you are modifying a definition, you must first check it out.Name
CDR_PUB_DF_BUSINESSAREA.ModifyBusiAreaDetails
Signature
PROCEDURE MODIFYBUSIAREADETAILS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_CDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Business Area and enter new values for the attributes you want to modify.
You can change the name, description, or version label for either a definition or instance. For an instance, you can also change to a different underlying source definition by entering values for the new definition in the three REF attributes. All attributes are required.
Use this API to check out a Business Area definition either directly or through an instance of it.
Name
CDR_PUB_DF_BUSINESSAREA.CheckOutBusiArea
Signature
PROCEDURE CHECKOUTBUSIAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2, PI_ISINSTONLY IN VARCHAR2 );
Parameters
- PIO_BASEOBJECT (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Business Area that you want to do check
out.
If you are checking out the Business Area definition directly, enter values to identify the definition.
If you are checking out a Business Area definition through an instance of it, enter values to identify the instance.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
- PI_COMMENT Enter the reason you are checking out the Business Area.
- PI_ISINSTONLY (Mandatory) Enter $YESNO$NO.
Use this API to undo the checkout of a Business Area definition, discarding any changes that have been made.
Name
CDR_PUB_DF_BUSINESSAREA.UncheckOutBusiArea
Signature
PROCEDURE UNCHECKOUTBUSIAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE );
Parameters
PIO_BASEOBJECT (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the Business Area whose checkout you want to undo.
Use this API to check in a Business Area definition.
Name
CDR_PUB_DF_BUSINESSAREA.CheckInBusiAreaDefinition
Signature
PROCEDURE CHECKINBUSIAREADEFINITION( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Parameters
CDR_BASE_OBJ_TYPE. Enter values to identify the Business Area that you want to check in.
- PI_COMMENT (Optional) Enter the reason you are checking in the Business Area.
Use this API to remove one or more Business Area definitions or instances.
Name
CDR_PUB_DF_BUSINESSAREA.RemoveBusiArea
Signature
PROCEDURE REMOVEBUSIAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
PIO_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs.
For each Business Area that you want to remove, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
This is a public interface for all Business Area hierarchy-related operations, including creating, modifying, and removing Business Area hierarchies and hierarchy columns.
- Create a Business Area Hierarchy
- Modify a Hierarchy and a Hierarchy Column
- Reorder a Hierarchy Column
- Remove a Hierarchy Column
- Remove a Business Area Hierarchy
Use this API to create a hierarchy in a Business Area. To define the hierarchy's columns, use ModifyBusAreaHierAndHierCol.
Name
CDR_PUB_DF_BUSINESSAREA_HIER.CreateBusinessAreaHier
Signature
PROCEDURE CREATEBUSINESSAREAHIER( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE.
Enter values for the new hierarchy. Use the NAMESPACE attributes to identify the Business Area in which you want to create the hierarchy.
The following attributes are required: OBJECT_TYPE_RC,NAME,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER,OBJECT_SUBTYPE_ID. For OBJECT_TYPE_RC enter $OBJTYPES$BUSAREAHIER.
Parent topic: Create and Modify Business Area Hierarchies
Use this API to modify Business Area hierarchies and hierarchy columns. You can change name and description, add columns, and change their Group With Previous setting. Use the remove columns API to remove columns.
Name
CDR_PUB_DF_BUSINESSAREA_HIER.ModifyBusAreaHierAndHierCol
Signature
PROCEDURE MODIFYBUSAREAHIERANDHIERCOL( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_NAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_BUS_HIERCOLUMNS_COLL IN OUT CDR_BUSAREA_HIER_COLS_COLL );
Parameters
- PIO_NAMING (Mandatory) This is a parameter of table type
Enter values to identify the Business Area Hierarchy that you want to modify and enter new values for the attributes you want to modify. You can modify only the Name and Description. All attributes are required.
- PI_BUS_HIERCOLUMNS_COLL (Mandatory) This is a collection of
CDR_BUSAREA_HIER_COLS_OBJ_TYPE.
Initialize a CDR_BUSAREA_HIER_COLS_OBJ_TYPE for each Column in their position order with the values you want to change, and then extend the collection. All attributes are required.
Use this API to reorder the Columns of a Business Area Hierarchy.
The API enforces validation rules for Column sequence.Name
CDR_PUB_DF_BUSINESSAREA_HIER.ReorderHierCols
Signature
PROCEDURE REORDERHIERCOLS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BUS_HIERCOLUMNS_COLL IN OUT CDR_BUSAREA_HIER_COLS_COLL );
Parameters
PIO_BUS_HIERCOLUMNS_COLL (Mandatory) This is a collection of CDR_BUSAREA_HIER_COLS_OBJ_TYPEs. For each Column, initialize a CDR_BUSAREA_HIER_COLS_OBJ_TYPE, providing the new value for POSITION NUMBER relative to the other Columns, and then extend the collection. You must initialize all existing Columns.
The following attributes are required: COMPANY_ID,HIER_OBJ_ID,HIER_OBJ_VER,TD_COMPANY_ID,TD_OBJ_ID,TD_COL_COMPANY_ID,TD_COL_OBJ_ID,POSITION,GROUP_WITH_PREVIOUS_RC.
Use this API to remove Business Area Hierarchy Columns.
You cannot remove a Column that is currently part of a Join. If you remove a Column, and if the next Column's Group By Previous setting is Yes, then that setting is changed to No.Name
CDR_PUB_DF_BUSINESSAREA_HIER.RemoveHierColumns
Signature
PROCEDURE REMOVEHIERCOLUMNS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BUS_HIERCOLUMNS_COLL IN OUT CDR_BUSAREA_HIER_COLS_COLL );
Parameters
PIO_BUS_HIERCOLUMNS_COLL (Mandatory) This is a collection of CDR_BUSAREA_HIER_COLS_OBJ_TYPEs. For each Column that you want to remove, initialize a CDR_BUSAREA_HIER_COLS_OBJ_TYPE and then extend the collection.
Use this API to remove one or more Business Area Hierarchies, including all their Columns.
Name
CDR_PUB_DF_BUSINESSAREA_HIER.RemoveHiers
Signature
PROCEDURE REMOVEHIERS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_BASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
PI_BASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs. For each Hierarchy that you want to remove, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
This is a public interface for Business Area Join-related operations, including creating, modifying, and removing Business Area Joins and Join Columns.
Create a Join
Use this API to create a Business Area Join.
Name
CDR_PUB_DF_BUSINESSAREA_JOIN.CreateBusinessAreaJoin
Signature
PROCEDURE CREATEBUSINESSAREAJOIN( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_BUSAREAJOINSOBJTYPE IN CDR_BUSAREA_JOINS_OBJ_TYPE );
Parameters
CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the Join that you want to create. Use the
NAMESPACE attributes to identify the Business Area in which you want to create the Join.
The following attributes are required: OBJECT_TYPE_RC,NAME,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER,OBJECT_SUBTYPE_ID. For OBJECT_TYPE_RC enter $OBJTYPES$JOIN.
- PI_BUSAREAJOINSOBJTYPE (Mandatory) This is a parameter of table type
CDR_BUSAREA_JOINS_OBJ_TYPE specific to Joins. Enter values for the Join that you want to
create.
The following attributes are required: TD_COMPANY_ID,TD_OBJ_ID,FK_TD_COMPANY_ID,FK_TD_OBJ_ID,TD_OUTERJOIN_RC,FK_TD_OUTERJOIN_RC.
For TD_OUTERJOIN_RC and FK_TD_OUTERJOIN_RC, enter $YESNO$NO to define an inner join on the side of the corresponding Table Descriptor, or $YESNO$YES to define an outer join. Be sure to define an outer join on only one side, if any.
Parent topic: Create and Modify Business Area Joins
Modify a Join and a Join Column
Use this API to modify Business Area Joins and Join Columns. You can change the name and description of the Join and change either side to an inner or outer join (but be careful not to make both sides into outer joins). You can add Join Columns and pair them with a different Column from the other Table Descriptor.
Do not change the operator. EQUAL TO is the only operator currently supported.Name
CDR_PUB_DF_BUSINESSAREA_JOIN.ModifyBusAreaJoinAndJoinCol
Signature
PROCEDURE MODIFYBUSAREAJOINANDJOINCOL( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_NAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_BUSINESS_JOIN IN OUT CDR_BUSAREA_JOINS_OBJ_TYPE, PI_BUS_JOINCOLUMNS_COLL IN OUT CDR_BUSAREA_JOIN_COLS_COLL );
Parameters
This API has standard parameters (see "Standard Parameters") and the following parameters:
CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Join that you want to modify and
for the attributes you want to change.
- PI_BUSINESS_JOIN (Mandatory) This is a parameter of table type CDR_BUSAREA_JOINS_OBJ_TYPE specific to Joins. Enter values to identify the Join that you want to modify and the values you want to modify. All attributes are required.
- PI_BUS_JOINCOLUMNS_COLL (Mandatory) This is a collection of
CDR_BUSAREA_JOIN_COLS_TYPEs. For each Join Column that you want to modify, initialize a
CDR_BUSAREA_JOIN_COLS_TYPE and then extend the collection.
The following attributes are required: COMPANY_ID,JOIN_OBJ_ID,JOIN_OBJ_VER,TD_COL_COMPANY_ID,TD_COL_OBJ_ID,FK_TD_COL_COMPANY_ID,FK_TD_COL_OBJ_ID,POSITION. You can change the joined columns but you cannot modify the operator, which is always Equal To.
Remove a Join Column
Use this API to remove one or more Columns from a Join.
Name
CDR_PUB_DF_BUSINESSAREA_JOIN.RemoveJoinColumns
Signature
PROCEDURE REMOVEJOINCOLUMNS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BUS_JOINCOLUMNS_COLL IN OUT CDR_BUSAREA_JOIN_COLS_COLL );
Parameters
PIO_BUS_JOINCOLUMNS_COLL (Mandatory) This is a collection of CDR_BUSAREA_JOIN_COLS_TYPEs. For each Join Column that you want to remove, initialize a CDR_BUSAREA_JOIN_COLS_TYPE and then extend the collection.
Remove a Join
Use this API to remove one or more Joins, with all their Columns, from a Business Area.
Name
CDR_PUB_DF_BUSINESSAREA_JOIN.RemoveJoins
Signature
PROCEDURE REMOVEJOINS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_BASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
For each Join that you want to remove from the Business Area, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
This is a public interface for operations related to Generic Visualization Business Areas including initializing and resetting them.
For more information on integrating a data visualization tool, see Oracle® Health Sciences Data Management Workbench Data Visualization Integration Guide on My Oracle Support, ID E87987-01.
- Initialize a Generic Visualization Business Area Instance
- Reset a Generic Visualization Business Area Instance
- Get Possible Blinding Types of a Business Area Instance
- Get Snapshot Labels Common to all Tables in a BA Instance for a Given Blinding AccessType
- Get Custom Listing Business Area ID
Use this API to initialize a business area instance with a given currency and blinding access type to determine which data is displayed. The visualization tool must run this API each time:
- A user logs in.
- The user changes the currency or blinding setting.
- A user selects a business area to view. Users can view multiple business areas in a
single session as long as the user selects
compatible blinding settings for all business
areas.
If the user selects a blinding access type for a business area that is incompatible with the blinding access types selected for other business areas in the same session, the API errors out with the message, "There is a change in reading dummy data to blinded data or vice-versa. Please reset access to all business areas using resetBAAccess api and try again." See Reset a Generic Visualization Business Area Instance.
If the currency and the blinding access values are not set by the user, the API uses the default values, which are to show current and nonblinded data.
Tip:
There are two versions of API CDR_PUB_API_GVA.setInitializeBa with the same name. One allows entering a timestamp for the currency, while the other one accepts either the value CURRENT or a snapshot label.
Signature for Version 1
PROCEDURE SETINITIALIZEBA( PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_VCURRENCY IN VARCHAR2, PI_VBLINDINGACCESSTYPE IN VARCHAR2, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2)
Signature for Version 2
PROCEDURE SETINITIALIZEBA( PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI__REFRESHTS IN DATE, PI_VBLINDINGACCESSTYPE IN VARCHAR2, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2)
Parameters
PI_COMPANYID. Enter the business area instance's company ID.
PI_OBJID. Enter the business area instance's object ID.
PI_OBJVER. Enter the business area instance's object version.
PI_VCURRENCY. Enter Current or a snapshot label common to all Table instances. See Get Snapshot Labels Common to all Tables in a BA Instance for a Given Blinding AccessType.
OR
PI_DREFRESHTS Timestamp of the data currency required. Use any valid Oracle date or datetime format. The system displays data that was current at the date and time specified. For example, if data was loaded for the first time at 1:00 pm and then again at 2:00 pm:
If the user specifies a timestamp of 1:30 pm, the visualization displays data loaded at 12:00.
If the user specifies a timestamp of 12:00 pm, the visualization displays no data.
If the user specifies a timestamp of 4:00 pm, the visualization displays data loaded at 2:00 pm.
PI_VBLINDINGACCESSTYPE. Enter the blinding access type. The allowed values are: NA/Dummy, Masked Data, Real(Unblinded), and Real(BlindBreak). Note that there is no space between Real and the parentheses/brackets.
NA/Dummy: The user sees dummy data for data blinded at the table level.
Masked Data: The user sees masking values for data blinded at the column, row, or cell level.
Real (Unblinded): The user sees real data in unblinded table instances. This option is available only if all the business area's table instances whose Blinding flag is set to Yes have a Blinding Status of Unblinded.
Real (Blind Break): The user sees currently blinded data in blinded table instances.
Real (Unblinded) and Real (Blind Break) can be specified together: The user sees unblinded data in business area instances where this option is available (all table instances that have their Blinding Flag set to Yes must have a Blinding Status of Unblinded) and currently blinded data in other business area instances in the same session.
Tip:
There is no space between
Realand the parentheses/brackets.
Use this API to clear all the initializations of Buiness Area schemas. It is equivalent to logging out and logging back in to the system. Use this API when you want to change blinding access type from blinded to unblinded or vice-versa.
Name
CDR_PUB_API_GVA.RESETBAACCESS
Use this API to get the possible Blinding Access Types of a Business Area Instance, which is in turn based on the blinding statuses of underlying Business Area Table instances and the user's privileges.
Name
CDR_PUB_API_GVA.GetBAValidBlindingAccessTypes
Signature
FUNCTION GETBAVALIDBLINDINGACCESSTYPES( PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE) RETURN BLINDINGACCESSTYPESCOLL PIPELINED;
Return
A collection of the possible blinding access types. BLINDINGACCESSTYPESCOLL is TABLE TYPE OF VARCHAR2(30);
Parameters
This API has the following parameters:
PI_COMPANYID. Enter the Business Area Instance Company ID.
PI_OBJID. Enter the Business Area Instance Object ID.
PI_OBJVER. Enter the Business Area Instance Object Version.
BLINDINGACCESSTYPESCOLL. This is the list of possible blinding access types.
Use this API to get the snapshot labels common to all Tables within a Business Area Instance for a given blinding access type.
Name
CDR_PUB_API_GVA.GetSnapshotLabels
Signature
FUNCTION GETSNAPSHOTLABELS( PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_VBLINDINGACCESSTYPE IN VARCHAR2) RETURN CURRENCYCOLL PIPELINED;
Return
A collection of the snapshot labels for a particular blinding access type in the Business Area instance common to all Tables within a Business Area Instance. CURRENCYCOLL is TABLE TYPE OF VARCHAR2(200);
Parameters
This API has the following parameters.
PI_VBLINDINGACCESSTYPE. Enter the Blinding Access Type.
When a user logs into a visualization tool, the visualization tool must call an API to initialize the primary data model schema and, if the user wants to see custom listings through the tool, the schema for custom listings. The initialization API requires the business area instance ID, which is not available to a user in DMW.
Use this API to fetch the ID of the business area instance that contains all the custom listings defined in the model.
Signature
FUNCTION getCustomListingBA( pi_nDataModelId IN NUMBER, pi_vContext IN VARCHAR2) RETURN NUMBER;
Parameters
pi_nDataModelId Enter the ID of the data model.
pi_vContext Enter the life cycle context value. The allowed values are: $LIFECYCLE$DEV, $LIFECYCLE$PROD, or $LIFECYCLE$QC.
