31 Flags, Categories, and Actions
This is a public interface for operations related to flags and actions. It contains the following topics:
Flag-Related APIs
This section contains the following procedures related to flags in the package DME_PUB_FLAG_DATA.
A program that calls any of these flag APIs must call DME_PUB_INITIALIZATION.SetupAPIStudyEnvironment to set the study and lifecycle context after calling CDR_PUB_API_INITIALIZATION.enableAPIs.
Set Flag
Use this API to set the state of a single flag for a given record.
Name
DME_PUB_FLAG_DATA.SetFlag
Signature
PROCEDURE SETFLAG,
( P_API_VERSION IN VARCHAR2,
P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,
P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,
P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
X_RETURN_STATUS OUT NOCOPY VARCHAR2,
X_MSG_COUNT OUT NOCOPY NUMBER,
X_MSG_DATA OUT NOCOPY VARCHAR2,
PI_COMPANY_ID IN NUMBER,
PI_TAB_OBJ_ID IN NUMBER,
PI_SKEY_VALUE IN VARCHAR2,
PI_TIMESTAMP IN DATE,
PI_FLAG_ID IN NUMBER,
PI_FLAG_STATE IN VARCHAR2,
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_COMPANY_ID (Mandatory). Enter the company ID.
  • PI_TAB_OBJ_ID (Mandatory). Enter the object ID of the table instance that contains the data record.
  • PI_SKEY_VALUE (Mandatory). Enter the surrogate key of the record.
  • PI_TIMESTAMP Enter the latest timestamp of the data record. The system tracks which version of the record the flag was initially applied to.
  • PI_FLAG_ID (Mandatory). Enter the unique ID of the flag (from dme_flag_names)
  • PI_FLAG_STATE (Mandatory). The flag state to be applied for the data record.
Get Flag
Use this API to retrieve information about an Oracle DMW flag setting.
Name
DME_PUB_FLAG_DATA.GetFlag
Signature
PROCEDURE GETFLAG
PO_FLAG_STATE OUT NOCOPY VARCHAR2,
Parameters
  • PI_TAB_OBJ_ID (Mandatory). Enter the obj_id of the table instance that contains the data record.
  • PI_SKEY_VALUE (Mandatory).The surrogate key of the record
  • PI_FLAG_ID (Mandatory). The unique ID of the flag (from dme_flag_names)
  • PO_FLAG_STATE (Mandatory). This output parameter inherits the flag state for this record.
Get Flags on Data
This API retrieves all the flags and their states, assigned to a particular data record, plus the latest update timestamp for each flag category per record.
It does not provide a timestamp for each individual flag update. If you want to see the update timestamp for a particular flag, you can create a category for that one flag.
Name
DME_PUB_FLAG_DATA.GetFlagsOnDataMore
Signature
PROCEDURE getFlagsOnDataMore
  ( p_api_version IN VARCHAR2
  , p_init_msg_list IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE
  , p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
  , p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
  , x_return_status OUT NOCOPY VARCHAR2
  , x_msg_count OUT NOCOPY NUMBER
  , x_msg_data OUT NOCOPY VARCHAR2
  , pi_company_id IN NUMBER
  , pi_tab_obj_id IN NUMBER
  , pi_skey_value IN VARCHAR2
  , pi_include_nulls IN NUMBER
  , po_flags OUT NOCOPY dme_flag_show_more_coll
  • PI_TAB_OBJ_ID (Mandatory). This input parameter is an object ID for a namings object of type $OBJTYPES$TABLEREF (table instance).
  • PI_SKEY_VALUE (Mandatory). Enter the surrogate key of the record whose flags you want to retrieve.
  • PI_INCLUDE_NULLS (Mandatory). Set this input parameter to 1 to include information for flags with NULL state, else 0.
  • PO_FLAGS (Output). This is a parameter of type DME_FLAG_SHOW_MORE_COLL that returns:
    • Flag ID
    • Flag Name
    • Flag Value
    • Flag State Priority Code
    • Flag State Priority Meaning
    • Category ID
    • Most Recent Category Update Date (The most recent update of any flag in the category.)
    • Category Update User ID (The user ID of the user or validation check that performed the most recent flag assignment update in the category.)
    • Category Update Username (The name of the user or validation check that performed the most recent flag assignment update in the category.)
Get Flags on Data Fuller
This API retrieves information about all the flag states on a particular record.
Name
DME_PUB_FLAG_DATA.GetFlagsOnDataFuller
Signature
PROCEDURE getFlagsOnDataFuller
  , po_flags OUT NOCOPY dme_flag_show_ver4_coll
  • PO_FLAGS (Mandatory). This is a parameter of type DME_FLAG_SHOW_VER4_COLL that returns: or the returned values (names, states, priorities, last category update date and last category update user)
    • Flag Name
Delete Flag
Use this API to delete an existing DMW Flag state.
Name
DME_PUB_FLAG_DATA.DeleteFlag
Signature
PROCEDURE DELETEFLAG
(P_API_VERSION IN VARCHAR2,
Parameters
  • PI_TAB_OBJ_ID (Mandatory). This input parameter is an object id for a namings object of type $OBJTYPES$TABLEREF (table instance).
  • PI_SKEY_VALUE (Mandatory). The surrogate key of the record.
  • PI_FLAG_ID (Mandatory). This input parameter is the ID of the flag whose state you want to remove.
Get Surrogate Key Values for Records in a Flag State
Use this API to get the surrogate keys for all records in a table that have the given state for the given flag.
Name
DME_PUB_FLAG_DATA.getRecordsForFlagState
Signature
PROCEDURE getRecordsForFlagState
 , pi_flag_id IN NUMBER
 , pi_flag_state IN VARCHAR2
 , pi_records OUT NOCOPY dme_char_coll);
Parameters
  • PI_TAB_OBJ_ID (Mandatory). Enter the object id for a namings object of type $OBJTYPES$TABLEREF (table instance) that contains the record.
  • PI_FLAG_ID (Mandatory). Enter the ID of the flag.
  • PI_FLAG_STATE (Mandatory). Enter the flag state.
  • PI_RECORDS This output parameter is a collection of type dme_char_coll.
Flag Name-Related APIs
Use the following APIs in the package DME_PUB_FLAG_NAME to retrieve DMW flag names definitions and states. Use the first version of these APIs if you know the flag ID; use the second one if you know its name.
This section includes the following:
Get Flag Name Definition, Version 1
Use this API to retrieve information about an Oracle DMW flag name definition. Use this API if you know the Flag Name ID.
Name
DME_PUB_FLAG_NAME.GetFlagName
Signature
PROCEDURE GETFLAGNAME
PI_FLAG_NAME_ID IN NUMBER,
PIO_DME_FLAG_NAME IN OUT NOCOPY DME_FLAG_NAME_TYPE,
Parameters
  • PI_FLAG_NAME_ID (Mandatory). Enter the ID of the flag name definition to be retrieved.
  • PIO_DME_FLAG_NAME (Mandatory). This is a parameter of type DME_FLAG_DEF_NAME for the returned values.
Get Flag Name Definition, Version 2
Use this API to retrieve information about an Oracle DMW flag name definition. Use this API if you know the flag name.
Name
Signature
PI_FLAG_NAMESTR IN VARCHAR2,
Parameters
  • PI_FLAG_NAMESTR (Mandatory). Enter the name of the flag name definition to be retrieved.
Get Flag Name Definitions
Use this API to retrieve information about DMW flag name definitions.
Name
DME_PUB_FLAG_NAME.GetFlagNames
Signature
PROCEDURE GETFLAGNAMES
PI_CATEGORY_ID IN NUMBER DEFAULT NULL,
PI_SUBJECT_VISIT IN VARCHAR2 DEFAULT NULL,
PI_USER_SETTABLE IN VARCHAR2 DEFAULT NULL,
PO_FLAG_NAMES OUT NOCOPY DME_FLAG_NAME_COLL,
Parameters
  • PI_CATEGORY_ID (Optional). Set to null to retrieve flags in all categories. To get flags from a given category, provide a valid category ID.
  • PI_SUBJECT_VISIT (Optional). Set to null to retrieve all flags irrespective of their being marked as subject_visit flags or not. To retrieve only subject_visit flags, enter either $YESNO$YES. To retrieve only record flags, enter $YESNO$NO.
  • PI_USER_SETTABLE (Optional). Set to null to retrieve flags whether or not they are settable by the user. To retrieve only user-settable flags, enter $YESNO$YES. To retrieve flags not settable by users, enter $YESNO$NO.
  • PO_FLAG_NAMES (Mandatory). This is a parameter of type DME_FLAG_NAME_COLL for the returned values.
Get Flag States
Use this API to retrieve information about all the DMW flag states for a single flag.
Name
DME_PUB_FLAG_STATE.GetFlagStates
Signature
PROCEDURE GETFLAGSTATES
PO_DME_FLAG_STATES OUT NOCOPY DME_FLAG_STATE_COLL,
Parameters
  • PI_FLAG_NAME_ID (Mandatory). Enter the ID of the flag.
  • PO_DME_FLAG_STATES (Mandatory). This is a parameter of type DME_FLAG_STATE_COLL for the returned information.
Clinical Data Model Category-Related APIs
You can create categories in the Oracle DMW Administration user interface.
Create Model Flag Category Mapping
Use this API to create a map between a model type and subtype and a flag category.
Name
DME_PUB_MODEL_FLAGCAT.CreateModelFlagcatMap
Signature
PROCEDURE CREATEMODELFLAGCATMAP,
PI_MODEL_TYPE_RC IN VARCHAR2,
PI_MODEL_SUBTYPE_RC IN VARCHAR2,
PI_CATEGORY_ID IN NUMBER,
Parameters
  • PI_MODEL_TYPE_RC (Mandatory). Enter a model type from the lookup CDR_MODELTYPES such as $MODELTYPE$INPUT.
    If you want to map a flag category to input models that come from files, pass these two arguments as '$MODELTYPE$INPUT' and '$INPUTMODTYPE$FILE'.
    If you want to map a flag category to input models from InForm, pass these two arguments as '$MODELTYPE$INPUT' and '$INPUTMODTYPE$INFORM'.
    If you want to map a flag category to target models, pass these arguments as '$MODELTYPE$TARGET' and NULL.
  • PI_MODEL_SUBTYPE_RC (Mandatory). Enter a model subtype; for example, $MODELTYPE$INPUT or $MODELTYPE$TARGET
  • PI_CATEGORY_ID (Mandatory). Enter the unique ID of the category (from dme_categories in the Administration Area of the DMW User Interface).
Get Categories for Model
Use this API to get all categories that are valid for a model type and subtype.
Name
DME_PUB_MODEL_FLAGCAT.GetCategoriesForModel
Signature
PROCEDURE GETCATEGORIESFORMODEL,
PO_CATEGORIES OUT NOCOPY DME_NUMBER_COLL,
Parameters
  • PI_MODEL_TYPE_RC (Mandatory). Enter a model type such as $MODELTYPE$INPUT, from the lookup CDR_MODELTYPES.
  • PI_MODEL_SUBTYPE_RC (Mandatory). Enter a model subtype; for example, $INPUTMODTYPE$FILE.
  • PO_CATEGORIES Output parameter returns an array of category IDs.
Action-Related APIs
Use the following APIs to perform tasks related to discrepancy actions:
Create Discrepancy Action
Use this API to create a new discrepancy action.
Name
DME_PUB_DISC_ACTION.CreateDiscAction
Signature
PROCEDURE CREATEDISCACTION   (P_API_VERSION IN VARCHAR2,   P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,   P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,   P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,   X_RETURN_STATUS OUT NOCOPY VARCHAR2,   X_MSG_COUNT OUT NOCOPY NUMBER,   X_MSG_DATA OUT NOCOPY VARCHAR2,   PIO_DME_DISC_ACTION IN OUT NOCOPY DME_DISC_ACTION_TYPE,) ;
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_DME_DISC_ACTION (Mandatory). This is a parameter of type DME_DISC_ACTION_TYPE that contains action attributes.
Enter the Start State, one of Candidate, Open, Answered, Cancelled, Closed. (In the API those are specified as $DISC_STATES$CANDIDATE, $DISC_STATES$OPEN. $DISC_STATES$ANSWERED, $DISC_STATES$CANCELLED, and $DISC_STATES$CLOSED).
Get Discrepancy Action, Version 1
Use this API to retrieve information about an Oracle DMW Discrepancy Action.
Name
DME_PUB_DISC_ACTION.GetDiscAction
Signature
PROCEDURE GETDISCACTION( P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PI_ACTION_ID IN NUMBER,  PIO_DME_DISC_ACTION IN OUT NOCOPY DME_DISC_ACTION_TYPE,  );
Parameters
  • PI_ACTION_ID (Mandatory). Enter the ID of the discrepancy action to retrieve information for it.
  • PIO_DME_DISC_ACTION (Mandatory). This is a parameter of type DME_DISC_ACTION_TYPE for the returned values.
Get Discrepancy Action, Version 2
Name
Signature
PROCEDURE GETDISCACTION,
PI_ACTION_NAME IN VARCHAR2,
Parameters
  • PI_ACTION_NAME (Mandatory). Provide the name of the discrepancy action to retrieve information for it.
Update Discrepancy Action
Use this API to modify an existing DMW Discrepancy Action.
Name
DME_PUB_DISC_ACTION.UpdateDiscAction
Signature
PROCEDURE UPDATEDISCACTION,
Parameters
  • PIO_DME_DISC_ACTION (Mandatory). This is a parameter of type DME_DISC_ACTION_TYPE that contains the discrepancy action attributes to be updated.
Delete Discrepancy Action
Use this API to delete an existing DMW Discrepancy Action.
Name
DME_PUB_DISC_ACTION.DeleteDiscAction
Signature
PROCEDURE DELETEDISCACTION,
PI_DME_DISC_ACTION_ID IN NUMBER,
Parameters:
This API has standard parameters (see Standard Parameters)and the following parameters:
  • PI_DME_DISC_ACTION_ID (Mandatory). This is a parameter of type NUMBER, that contains the unique ID of the category to be disabled.
