4 Use filters to find data and discrepancies
This section has information on the standard (quick) and advanced filters available in the Listings pages and in the Discrepancies page. Quick filters include a list of fields where you can enter data or select options from a drop-down list. Advanced filters include numerous categories with operators for you to build a filter formula from a list of drop-down options (depending on the criteria and operators you use). You can use the quick and advanced filters together, if necessary.
Tip:
By default, you cannot view canceled or closed discrepancies unless you use the Discrepancy State field in the filter. For more details, see Create a new filter.
For more details, see this video:
Create a new filter
Parent topic: Use filters to find data and discrepancies
Advanced Filters
As described in Create a new filter, you can find particular records and discrepancies by creating a filter (or using a previously saved one).
The filter panel includes an Advanced Filters field that allows you to use additional filter criteria with operators to build a formula. You can use advanced filters with or without the quick filter fields.
- Use the space bar to open the list of operators, categories, or
linking options.
The operators depend on the filter you choose. For example, you may see an operator of =, != (not equal to), is empty, or is not empty with one filter category or exactly, before, after, between, is empty, or is not empty with another category. Once you select a filter, operator, and value (if required), you can use the AND or OR linking options to build on the formula. - Use single quotes around any alpha characters you manually enter (for example, 'Boston').
- Use a comma (outside single quote if quote used) to add multiple entries or a range of numbers. For example, to show a range of 1 to 10, enter 1, 10.
- Select dates from the pop-up calendar. Click the left (<) or right (>) arrows to move backward or forward through the months. The date appears in the DD-MMM-YYYY format.
- Click
to remove the advanced filter from the formula.
- Click
to close the Advanced Filters text box.
The following table lists the advanced filters you can use to drill down to the data you need to access:
Table 4-1 Advanced filter options
| Advanced Filter | Available Operators | Description |
| Discrepancy Category | =, !=, is empty, is not empty | Lists the records with the discrepancy category that you specify (for example, From InForm, TMS IN PROGRESS, QC: Manual). |
| Discrepancy Change Date | exactly, before, after, between, is empty, is not empty | Lists the records with the most recent discrepancy change update that occurred during the time period you specify. |
| Discrepancy State Change Date | exactly, before, after, between, is empty, is not empty | Lists the records with the most recent discrepancy state change update that occurred during the time period you specify. |
| Discrepancy Created by User | =, !=, is empty, is not empty | Lists the records with the discrepancies created by the user you specify. |
| Discrepancy Modified by User | =, !=, is empty, is not empty | Lists the records with the discrepancies modified by the user you specify. |
| Discrepancy Origin | =, !=, is empty, is not empty | Lists the records with discrepancies that originate from the application you specify (for example, InForm, TMS). |
| Data Source Name (for Discrepancies only) | =, !=, is empty, is not empty | Lists the records from the data source you specify (for example, InForm, Undetermined). |
| Data Source Type (for Discrepancies only) | =, !=, is empty, is not empty | Lists the records for the data source type you specify (for example, InForm, Unknown). |
| Record Level Flag | =, != | Lists the records with the flag priority level you specify. |
| Subject Visit Flag | =, != | Lists the records with the subject visti flag you specify. |
| Site ID | =, !=, is empty, is not empty | Lists the records with the site ID values you specify. |
| Investigator Name | =, !=, is empty, is not empty | Lists the records with the investigator names you specify. |
| Investigator ID | =, !=, is empty, is not empty | Lists the records with the investigator IDs you specify. |
| Unique Subject ID | =, !=, is empty, is not empty | Lists the records with the unique subject IDs you specify. |
| Visit Date | exactly, before, after, between, is empty, is not empty | Lists the records with the visit date you specify. |
| Visit Day | =, !=, >, >=, <, <=, between, is empty, is not empty | Lists records with the visit day numeric values you specify. |
| Visit Number | =, !=, is empty, is not empty | Lists records with the visit number values you specify. |
| Visit Cycle | =, !=, is empty, is not empty | Lists records with the one or more visit cycle numeric values you specify. |
| Data change date (for Listings only) | exactly, before, after, between, is empty, is not empty | Lists records that data that changed during the time period you specify. |
| Discrepancy Reopened | = | Lists records that do or do not include discrepancies that were reopened. Can specify Y (for yes) or N (for no). |
| Discrepancy Data Changed | = | Lists records that do or do not include discrepancies with changed data. Can specify Y (for yes) or N (for no). |
Parent topic: Create a new filter
Delete a filter
To delete a filter, follow these steps:
Create a public filter
If your account includes the appropriate privileges, you can make a filter public. Data reviewers can:
Use any public filter.
Change public filter values temporarily.
Change public filter values and save them using a different name.
FAQs
- How do data filters work on the Discrepancies page?
- How do I know if any filters are applied?
- How can I tell which filters are applied?
- How do I turn filters off?
- Why can't I make my filters public?
When you open the Discrepancies page from the Listings page (Discrepancies > Go to Discrepancy) and you leave the Keep the Filter in effect option selected in the Filters panel, the system continues to apply the same filters with these exceptions:
If any of the current Subject or Visit filters only apply to a specific data model, the system only displays discrepancies in that model.
If different Subject and Visit filters have different driver data models and they are applied at the same time, the system ignores all Subject and Visit filters.
A message appears when any of these conditions occur.
Parent topic: FAQs
- If the page includes filtered data, the Filter field appears as
On:
If you select the drop-down for the field, you see the toggle switch show blue with a white circle to the right when the page uses one or more filters:
You also see a list of any filters used, including advanced filters. For example, if you used the Site or Discrepancy State filter, you see it listed as an applied filter in the drop-down list.
- If the page does not include filtered data, the Filter field appears
as Off:
If you select the drop-down, you see the toggle switch show gray with a white circle to the left:
Parent topic: FAQs
To determine the current filters in use on the Listings or Discrepancies page, select the drop-down list from the Filter field on the left of the navigation bar (Filter: On). You see a list of one or more filters applied to the data (including advanced filters, if used). For example, if the data uses the Discrepancy State field, you see it listed with the state used for the filter:
If the Filter field appears as Filter: Off, the data was not filtered.Parent topic: FAQs
From the Listings or Discrepancies page, you can turn the filters off by selecting Clear from the Filters tab or panel on the left.
Parent topic: FAQs
To make a filter public, your account needs the appropriate privileges. For more details, see Create a public filter.
Parent topic: FAQs
