Add users and assign roles
The group administrator adds users to a group, at the same time assigning the user to one or more roles within the group.
  1. Log in to Oracle LSH.
  2. Expand the Life Sciences Data Hub node in the main menu on the left or from the Navigator drop-down. Select User Groups.
    Or, if Oracle LSH is already open, go to the Security tab and select the User Groups subtab.
  3. In the user group box, type the name of the user group where you want to assign users.
    If you are not sure of the name, you can use % as a wildcard.
  4. Click Search. The system displays all the groups you administer that match the search criteria.
  5. Click the required user group. The Group screen appears.
  6. Click the plus (+) icon to see the roles assigned to the user group.
  7. Find the role you want to assign to the user you are adding, and click its Add User icon.
    For more details on roles, see Security reference information.
  8. Type the user name, first name, and/or last name of the user.
  9. Click Search. All the users matching the search criteria appear.
  10. Select one or more users you want to assign to the role.
  11. Click Select. The system assigns the selected user(s) to this role within this user group and returns to the User Group screen.
  12. Repeat until you have added all the users and given each user all the roles he or she needs within the group.
  13. When you finish, see Clear the Oracle Applications cache.
