Clear the Oracle Applications cache
Every time you change user assignments to a user group, clear the Oracle Applications cache so that users logging into Oracle LSH see only the appropriate options. (Note that if you do not clear the cache, users may be able to see the wrong options but they cannot actually do them.)
  1. Log in as an Oracle LSH user with the Functional Administrator responsibility. See Assign application roles to users for instructions on granting this responsibility.
    The Security tab's Grants screen appears.
    You can also log in as the sysadmin user if you do not want to assign the Functional Administrator responsibility only for the purpose of clearing cache.
  2. Click the Core Services tab from the Grants screen. The Lookup Types screen appears.
  3. Click Caching Framework from the list of secondary tabs. The Overview screen opens.
  4. Click Global Configuration from the left panel. The Global Cache Configuration screen opens.
  5. Click Clear All Cache. A warning appears.
    Click Yes.
