Copy user groups with or without users
You can create copies of a user group in two ways. Either you can duplicate only the user group definition with its supported roles or you can duplicate the definition with its supported roles and also the users assigned to it and their role assignments. When you duplicate a user group, the system appends 'Copy of' to the name of the user group.
  1. Log in to Oracle LSH.
  2. Expand the Life Sciences Data Hub node in the main menu on the left or from the Navigator drop-down. Select User Groups.
    Or, if Oracle LSH is already open, go to the Security tab and select the User Groups subtab.
  3. Enter a search string—the name of the user group you want to duplicate in the User Group box or text with the wildcard %, or leave blank to retrieve all user groups.
  4. Click Go. All the user groups matching the search criteria appear.
  5. Click the Select checkbox corresponding to the required user group.
  6. Click Duplicate with Roles or Duplicate with Roles, Users.
