Assign roles to operations
Users assigned to a role within a user group will be able to perform the operations you assign to the role.
To assign roles to operations, go to the Subtype subtab of the Security tab and do the following:
  1. Log in to Oracle LSH.
  2. Expand the Life Sciences Data Hub node in the main menu on the left or from the Navigator drop-down. Select Subtypes.
    Or, if Oracle LSH is already open, go to the Security tab and select the Subtypes subtab.
  3. From the View Subtype By drop-down, select Operation.
  4. Expand the node (+) of the object type. All the subtypes appear.
  5. Expand the node (+) of the object subtype. All the subtype's operations appear.
  6. Click the icon in the Manage column of the operation to which you want to assign or remove a role. The Add Role(s) to Operation screen appears.
  7. Double-click on a role in the Available Roles column to move it into the Selected Roles column to assign it to the role. Or move it from Selected Roles to Available Roles to remove the assignment.
    • Select multiple roles using Shift+Click or Control+Click and move them by clicking the arrows.
    • To promote an input clinical data model to QC or Production, a user must have a role with the "Modify Val Status to QC" or "Modify Val Status to PROD" operation on load sets as well as on data models.
  8. Click Apply. The system assigns the role(s) to the operation on the subtype and the Manage Subtype screen appears.
