Enable UI changes for a clinical data system other than InForm
It is possible to integrate a clinical electronic data capture (EDC) system other than InForm with DMW. See Using the Generic Connector to Integrate DMW with a Clinical Data System, My Oracle Support article 2172786.1.
This profile makes changes in the UI required for the integration, including a tab for a new input clinical data model type called External_System Configuration, new actions for sending discrepancies to the external system, and a new web service location type.
  1. Log in. See Set profiles to determine system behavior.
  2. In the Profile field, enter DMW_GC_ON
  3. Click Find.
  4. In the Site column, set to OUI to make user interface changes related to the external system integration visible.
  5. In the File menu, select Save and Proceed.
