Turn debugging on or off
Enable or disable the recording of debugging statements for database processes. The setting applies to all users. The system reads the value of the profile once per user session, so you may need to restart the application tier for a changed setting to take effect.
  1. Log in. See Set profiles to determine system behavior.
  2. In the Profile field, enter LSH:ENABLE_DEBUGGING
  3. Click Find.
  4. In the Site column, enter:
    • Y to enable debugging.
    • N to disable debugging.
  5. In the File menu, select Save and Proceed.
