Increase the maximum number of nested domains
LSH: Domain Nesting Levels should be set to at least 6 because three levels of domains are predefined for Oracle DMW and you will need more to create categories such as Therapeutic Areas.
- Log in. See Set profiles to determine system behavior.
- In the Profile field, enter
. - Click Find.
- In the Site column, enter a number between 6 and 9. Oracle recommends
9
. - In the File menu, select Save and Proceed.
Parent topic: Set profiles to determine system behavior
