Use character semantics
On each computer where you install Oracle DMW, you must set the Oracle Applications profile LSH: Use Character Semantics for Workarea Installation to Yes, as instructed in the Oracle Life Sciences Data Hub Installation Guide.
  1. Log in. See Set profiles to determine system behavior.
  2. In the Profile field, enter LSH: Use Character Semantics for Workarea Installation.
  3. Click Find.
  4. In the Site column, select YES.
  5. In the File menu, select Save and Proceed.
