Set up a data visualization tool
You can integrate an external data visualization tool so that users can view data graphically and interactively with the protection of Oracle DMW security and blinding access privileges.
Visualization tools access one clinical data model at a time, along with any custom listings that read from the model. If you are using custom listings, we recommend setting a profile value as detailed in Use custom listing name for the custom listing schema.
You can use:
  • Third-party tools that use generic-type business areas to work with Oracle LSH and Oracle DMW.
  • Oracle Business Intelligence Enterprise Edition (OBIEE). An adapter is included with Oracle LSH. See the Oracle Life Sciences Data Hub Installation Guide and System Administrator's Guide for instructions.
    To use OBIEE, you must create business areas in Oracle LSH. The business areas that are created automatically for a clinical data model in Oracle DMW are "generic," not specialized for OBIEE. See the Oracle Life Sciences Data Hub Application Developer's Guide for instructions.
  • You can build an integration to a different tool. See the DMW Data Visualization Integration Guide, My Oracle Support article 2284413.1. If you are using custom listings, use the API CDR_PUB_API_GVA.getCustomListingBA.
To allow users to see data in a particular DMW clinical data model, the study configurator must select the Business Area option for the model.
