Set up lab and other file-based data sources
This list populates the list of values for creating file-based input clinical data models. Add each lab and any other entity that sends data files to Oracle DMW. If you are using a clinical electronic data capture system other than Oracle Health Sciences InForm, enter it here.
  1. Click Shows a computer monitor Navigation from the navigation bar and then click Administration.
  2. Make sure the Data Sources tab is selected, then click the Labs subtab.
  3. Click the Icon is a plus sign.Add icon.
  4. Data Source Name: Enter the name of the data source; for example, Central Lab. This value appears in the list of data sources in the File Watcher configuration tab for file-type input clinical data models.
    The system uses only the data source name. All other fields are for your own records.
    The Send All Open Discrepancies? field has no effect in this release.
  5. Click OK.
