TMS processing
When DMW is integrated with TMS, transformation jobs have additional steps: they send new and updated source terms (data in specified columns) to TMS, run the TMS autoclassification job, and derive TMS data into DMW tables.
Terms that cannot be automatically coded must be manually coded in TMS. TMS then codes all future occurrences of the same term the same way within the same domain.
If a TMS user cannot classify the term because of a problem with the term, for example, it is really multiple terms, like nausea and headache, he or she can send a TMS action back to DMW as discrepancy text. The discrepancy is then sent to InForm.
