Turn on tracing or logging
Logging and tracing begin for each user when he or she logs in after the request has been made. They begin immediately for your own session.
  1. Click Shows a computer monitor Navigation from the navigation bar and then click Administration.
  2. Click the Tracing and Logging tab.
  3. Click the Icon is a plus sign. Add Session icon.
  4. Session Type: Select either Logging or Tracing.
  5. Session Scope: Select either System (all users) or User.
  6. If you selected User, select the user from the User drop-down.
  7. If you selected Tracing for a particular user, enter a trace file identifier string to help you find the file on the database server.
    Logging data is written to the table CDR.CDR_EXE_DEBUG.
