View past and current job executions
Use this page to query for jobs that have already run and jobs that are currently running. You can cancel jobs that are in progress.
  1. Click Shows a computer monitor Navigation from the navigation bar and then click Administration.
  2. Click the Job Execution tab.
  3. To find jobs:
    • Query in the Search Jobs pane. To search by date, job status, or submitting user, click Advanced.
    • To filter results further, enter a string in the blank field above any column. If the blank fields are not displayed, click the Icon is a funnel in front of data. Query By Example icon.
  4. To cancel a job, select it and click the Icon is an X. Cancel icon. You can only cancel jobs that currently have the status In Progress or Executing.
