Create Model Flag Category Mapping
Use this API to create a map between a model type and subtype and a flag category.
Name
DME_PUB_MODEL_FLAGCAT.CreateModelFlagcatMap
Signature
PROCEDURE CREATEMODELFLAGCATMAP, (P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PI_COMPANY_ID IN NUMBER, PI_MODEL_TYPE_RC IN VARCHAR2, PI_MODEL_SUBTYPE_RC IN VARCHAR2, PI_CATEGORY_ID IN NUMBER, );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_COMPANY_ID (Mandatory). Enter the company ID.
- PI_MODEL_TYPE_RC (Mandatory). Enter a model type from the lookup
                    CDR_MODELTYPES such as $MODELTYPE$INPUT.
                        If you want to map a flag category to input models that come from files, pass these two arguments as '$MODELTYPE$INPUT' and '$INPUTMODTYPE$FILE'. If you want to map a flag category to input models from InForm, pass these two arguments as '$MODELTYPE$INPUT' and '$INPUTMODTYPE$INFORM'. If you want to map a flag category to target models, pass these arguments as '$MODELTYPE$TARGET' and NULL.
- PI_MODEL_SUBTYPE_RC (Mandatory). Enter a model subtype; for example, $MODELTYPE$INPUT or $MODELTYPE$TARGET
- PI_CATEGORY_ID (Mandatory). Enter the unique ID of the category (from dme_categories in the Administration Area of the DMW User Interface).
Parent topic: Clinical Data Model Category-Related APIs
