Assign a flag to a record
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the navigation bar.
    For details on selecting a study, see Select a study.
  2. Select Listings from the drop-down menu.
  3. Expand Default Listings listings in the left panel. Then, expand a clinical data model from the list.
  4. Select a listing to open it.
  5. Select the row with the record you want to flag, right-click anywhere in the row and click Assign Flags. Or, click Flags > Assign Flags. (To assign the same flag to multiple records, select the records by pressing the Shift or Ctrl key while you select records.) The Assign Flags dialog box opens.
    Tip:
    You can skip the remaining steps and use keyboard shortcuts to assign a flag to a record by pressing Ctrl+Alt+F. Use the down arrow keys to select options and press Tab to navigate to fields and buttons.
  6. In the Flags field, select the previously created flag name you want to use from the drop-down list.
  7. In the States field, select the previously created state name from the drop-down list. The names are associated with a high, medium, or low flag state.
  8. Click Assign. You can see the flag state in the first column of the listing (up and red for high state, sideways and yellow for medium, or down and green for low).
    Tip:
    If a data load completes while you were viewing the page, you see a prompt to refresh the page and Oracle DMW cannot assign the flag. Click the Refresh iconIcon is a near circular arrow. and check the data. If the flag still applies, assign it again.
