Data Review Guide View data listings, display data flow, and create discrepancies Review data Assign and remove flags Remove a flag Remove a flag After you select a study, click Data Management in the navigation bar. Note:For details on selecting a study, see Select a study. Select Listings from the drop-down menu. Expand Default Listings listings in the left panel. Then, expand a clinical data model from the list. Select a listing to open it. Select the row with the flag by clicking the arrow icon at the beginning of the row (first column). Tip: To select multiple records with flags, press the Shift or Ctrl key while you select records. Right-click and select Show Flags. The Show Flags dialog box opens. Select the flag you want to clear and click the Clear Flag icon on the right. Note:You cannot remove flags assigned in InForm. InForm flags use a prefix of Inf_. Click OK. Parent topic: Assign and remove flags
