Cancel a transformation job
As described in Run a transformation, you access transformation through the Transformations tab on the Home page. Select a transformation in the Run History pane and click:
Cancel Job to cancel the currently running or next pending job.
Cancel All Jobs to cancel the currently running or next pending job and all future jobs in the schedule for the selected transformation. Available only for scheduled jobs.
If there is an immediate or deferred job for the same transformation, or another schedule for the same transformation, those jobs are not affected.
Cancel Triggered Job to cancel the currently running or pending job. Available only for jobs that are set up to be triggered by another job.
Parent topic: Run transformations and view run history
