Run validation check batches and view run history
  1. Click Icon is a house. Home in the navigation bar and select a study from the Studies panel.
    For details on selecting a study, see Select a study.
  2. Click the Validation Checks tab to open tables with details on the validation check batches for a model and run history.
  3. From the Model field, select the clinical data model from the drop-down list.
  4. Select a validation check batch from the Validation Check Batches for Model <model name>.
    The system displays information about its validation checks in the middle pane and information about its run history in the lower pane.
  5. To view all jobs, click the Icon shows a clock and a report. View Full Job History icon.
    To view only recent jobs again, click the Icon shows a funnel and a report. View Recent Jobs Only icon.
    To view log files, click the icon in the column for the type of job:
    • Log (Run History pane) The most recent manually submitted job.
    • Triggered Job Log (Run History pane) The most recent triggered job.
    • Install Job Log (Validation Check Batch pane) The most recent installation of the validation check batch.
    A validation check can be disabled so that it is not included in the batch execution. To find out if a check was included in the run, check the log file.
