Find the discrepancies you need to locate using the filters on the left panel
or the top of the page. (See Find discrepancies for details on using the filters.)
Select a discrepancy.
In the right panel, click Edit.
Tip:
You can skip the
remaining steps and use keyboard shortcuts to edit one discrepancy at a time
by pressing Ctrl+Alt+E. Edit the Discrepancy field (if
available). Press Tab to navigate to the Category field (if
necessary), use the down arrow key to open the drop-down menu and select an
option. Press Tab to navigate to Submit and press
Enter.
Edit the Discrepancy field, Category field, or both. You can also
select or clear the Allow Auto Close option. (You cannot change the state
of the discrepancy.)
