Export discrepancies on lab data
To send discrepancies to a lab, create a file, and email it manually, follow these steps.
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the navigation bar.
    For details on selecting a study, see Select a study.
  2. Select Discrepancies from the drop-down menu.
  3. Find the discrepancies you need to locate using the filters on the left panel or the top of the page. (See Find discrepancies for details on using the filters.)
  4. If you want to export only selected discrepancies, select the discrepancies. To select adjacent rows, press Shift as you click rows (or press the down arrow key). To select nonadjacent rows, press Ctrl as you click rows.
  5. Select one of the following from the Export drop-down list:
    • All to Excel
    • All to CSV
    • Selected to Excel
    • Selected to CSV
    The system exports all or selected data to a Microsoft Excel or CSV file and prompts you to save it.
