Show all discrepancies on one data item
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the navigation bar.
    For details on selecting a study, see Select a study.
  2. Select Listings from the drop-down menu.
  3. Expand one of the listings in the left panel (Default Listings, Custom Listings, or VC Listings). Then, expand a clinical data model from the list.
  4. Select a listing to open it.
  5. Select a data item.
  6. Click Details at the top of the table to open the Discrepancies panel on the right.
  7. Expand Additional Information to view more details. For example, you can click View in Source to access the source of the data (if connected to InForm or another supported source). Or, click Assign Flags to assign a flag and state to the data point.
    Tip:
    To view details or act on one of the discrepancies, right-click the data item, and select Go to Discrepancies from the drop-down menu. Select one discrepancy to see its details in the lower panel.
