View discrepancy details
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the title bar.
    For details on selecting a study, see Select a study.
  2. Select Listings from the drop-down menu.
  3. Expand one of the listings in the left panel (Default Listings, Custom Listings, or VC Listings). Then, expand a clinical data model from the list.
  4. Select a listing to open it.
  5. Select one or more data items with a discrepancy.
  6. Right-click and select Go to Discrepancies from the drop-down menu. Or, click Discrepancies > Go to Discrepancies (or Show All Discrepancies to see all of them).
  7. Select a discrepancy from the Discrepancies panel on the right to see details on it.
