Use keyboard shortcuts on discrepancies
After you open the Discrepancies page, and select one or more discrepancies, you can save time and avoid using a mouse by using keyboard shortcuts to perform actions or use search fields. (The number of actions you can take on a discrepancy vary depending on the state of the discrepancy.)
Table 3-1 Keyboard Shortcuts for Discrepancies
| Keyboard Shortcut | Description |
| Ctrl+Alt+S | Search for a column value: Use the keyboard shortcut and press Enter to open the Search field drop-down list and select the column you want to search. For more details, see Use the search fields at the top. |
| Ctrl+Alt+E | Edit a discrepancy: Opens the Edit Discrepancy
dialog box in the right panel. For more details, see Change discrepancy text or category.
Note: You can only edit one discrepancy at a time. To open the Edit Discrepancy dialog box for more than one discrepancy at a time, select multiple discrepancies and click Edit for each discrepancy you opened. Do not use the keyboard shortcut. |
| Ctrl+Alt+Q | Ready to Send to InForm (if available): Opens the Ready to Send to InForm dialog box in the right panel. For more details, see Change the state or send to InForm or another system. |
| Ctrl+Alt+C | Close one or more discrepancies: Opens the Close Discrepancy dialog box in the right panel (for one or more discrepancies). For more details, see Change the state or send to InForm or another system. |
Parent topic: How do I create a discrepancy?
