3.8 Start the Node Manager and Check Settings
You can use the Node Manager to start and stop the Administration Server and the Managed Server and to start the server. If the following settings are not correct, change them manually.
- Start the node manager; see "Starting and Stopping Node Manager" in the Oracle Fusion Middleware Administering Oracle Fusion Middleware guide on Oracle Help Center.
- In the nodemanager.properties file, located at $DOMAIN_HOME/nodemanager, set:
                     StartScriptEnabled = TRUE
- The Managed Server listener address must be correct for your environment. It
                defaults to localhost, which causes problems when restarting the Node Manager.
                     - Log in to the WebLogic Server Console, then click Environment, then Machines. Select DMWMachine, then Node Manager.
- Change the value for Listen Address to the correct hostname for your environment.
Parent topic: Install Oracle WebLogic Server
