Assign dictionaries for coding (optional)
To use Oracle Thesaurus Management System (TMS) to code terms in a study, specify the dictionaries and TMS domains to use.
Prerequisite: Dictionaries and TMS domains must be defined in TMS.
Go to the
Home page.
Select a study and click the
Modify icon in the Studies pane.
Click the TMS tab.
For each base terminology (dictionary) needed in the study, select a TMS Domain from the drop-down list.
TMS domains allow you to code terms differently in different studies. Domains also determine TMS system behavior, including whether explicit approval is required for manual classifications.
Click OK.
Back to Table 1-1.
Parent topic: Study configuration basics
