Force rederivation of TMS data
Normally, only new or changed data is sent to TMS for processing. Use Force Rederivation to resend all data designated as needing coding in TMS when you have made structural changes such as:
Adding columns to hold derived data in DMW target tables.
Updating a dictionary in TMS to a new version with a different structure from the old version.
Changing domain-related settings in the TMS reference codelist TMS_CONFIGURATION.
Running this job triggers the execution of the downstream transformation.
To force rederivation of all data from TMS:
Go to the Home page.
Select a study.
Click the Modify icon in the Studies pane.
Click the TMS tab.
Click Force Rederivation to run Rederivation once, immediately.
A confirmation message appears because the job may take a long time. You can still work while it runs. Click OK.
Force Rederivation is not part of setting up TMS in a study. You only run it in a live study, after making the changes described above.
Parent topic: Assign dictionaries for coding (optional)
