Configure the InForm Connector
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models
tab.
Select Development from the Lifecycle drop-down at the top of the page.
Open the InForm clinical data model that you have created. (If necessary, see Create a clinical data model for InForm data for details on creating data models.)
If you haven't already checked out the InForm clinical data model, click Check Out.
In the InForm Configuration tab, for each lifecycle stage, in the Remote Location field, specify the InForm reporting database from which to load data.
Remote Study Account Name: Enter the name of the database account that owns the study's InForm reporting database and RDE views for the appropriate DMW lifecycle stage.
You can change the InForm configuration for any lifecycle to use a different remote location and/or remote study account name. If you do, the system runs a metadata comparison between the InForm model in DMW and the InForm metadata at the new location. If there are differences, the metadata comparison report is displayed. If you accept the changes, data loading is suspended. Reload metadata before resuming data loading.
When you reload metadata, you must redo any blinding and masking you've done in DMW.
InForm LifeCycle: Select the InForm lifecycle stage of the study account name.
Webservice Location: Specify the web service location.
InForm URL: Enter the URL for the study's InForm website.
http://your_InForm_server.your_company.com/your_trial/pfts.dll
Click the
Test URL icon on the far right. If the InForm login page opens, the URL is correct. The new window may open behind the current one.
Click the
Save icon.
Next: Select internal InForm tables and views for data transformations.
Parent topic: Create a clinical data model for InForm data
