Create a clinical data model for InForm data
For details on creating a clinical data model for InForm data, see this video:
On the
Home page, select the study and the Development lifecycle stage.
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models
tab.
Click the
Add icon for Clinical Data Models at the top of the left pane.
Enter a name and description. See Naming restrictions for details.
For the model type, select Input.
For Input Type, select InForm.
To allow visualization tools access to the data contained in the clinical data model, select the Business Area checkbox.
You can change the default schema name, BA_model_name. This is what users of the visualization tool will see. Limitation: Use a maximum of 19 characters for the schema name if you plan to create custom listings on the model. Do not use spaces or special characters other than underscore (_).
For InForm models, business areas for InForm metadata and operational data models are also created, with "M" and "O" in their names, respectively. For example, STUDY12345_M_QC is the name of the metadata model's business area in the quality control lifecycle.
Data Mart: A data mart file contains all current data in a clinical data model for export to an external system. Select data mart type(s) to make available:
Only the types that are available in your environment are displayed.
- Oracle Export
- Text Export
- SAS Export
Click OK.
Tables with more than 339 columns may cause problems with data loading, transformations, and display in the Listings pages. See My Oracle Support article 2298558.1 for the latest information.
Next:
