Compare DMW and InForm Metadata
You can compare the metadata—table and column structure—in any DMW InForm model lifecycle stage to any InForm lifecycle database for the same study.
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models
tab.
In the clinical data model InForm Configuration tab, click the
Compare DMW and InForm Metadata icon.
In the Metadata Comparison window, select the metadata to compare in DMW and InForm.
Click Compare. The report appears on screen.
To save the report, click the
Export All to Excel icon.
If the system finds no differences, a message appears.
For more information, see InForm metadata change detection and synchronization.
Back to Set up clinical data models
Parent topic: Create a clinical data model for InForm data
