Create a target clinical data model for transformed data
For details on creating a target clinical data model for transformed data, see this video:
On the
Home page, select the study and the Development lifecycle stage.
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models
tab.
Click the
Add icon for Clinical Data Models at the top of the left pane.
Enter a name and description. See Naming restrictions for details.
For model type, select Target.
For Metadata Source select:
None to define tables and columns manually.
Load from file.The system can create tables from a .zip file that contains one (.mdd) file per table. See Required syntax for metadata files.
SAS Transport (CPort or XPort) files, a SAS dataset, or a .zip file that contains SAS datasets or text metadata (.mdd) files (not both).
Tables created by uploading SAS datasets are created as nonblinded. If data should be blinded, you must define blinding attributes manually for tables in the input data model.
- You can create a table from a metadata file and load data into it from a SAS file. Metadata files are the only automated way to create tables with blinding attributes set.
- Tables with a large number of columns may cause problems with data loading, transformations, and display in the Listings pages. The supported maximum ranges from 260 columns if all columns are individually blinded to 370 columns if the table is either not blinded, has only row blinding, or is completely blinded. See My Oracle Support article 2298558.1 for the latest information.
Library Data Model to create a study model from a standard library model. If the library model is updated, you can update the study model.
Study Data Model to copy a model from another study. Select its project (or other grouping), then its study, and then the model.
The Copy operation includes transformations that write to the model and validation checks that read from the model.
You can also Add tables manually.
To allow visualization tools access to the data contained in the clinical data model, select the Business Area checkbox.
You can change the default schema name, BA_model_name. This is what users of the visualization tool will see. Limitation: Use a maximum of 19 characters for the schema name if you plan to create custom listings on the model. Do not use spaces or special characters other than underscore (_).
Data Mart: A data mart file contains all current data in a clinical data model for export to an external system. Select data mart type(s) to make available:
Only the types that are available in your environment are displayed.
Oracle Export
Text Export
SAS Export
Click OK.
Back to Set up clinical data models
Parent topic: Set up clinical data models
