Compare records in data listings
You can select up to 100 records within the Listings grid to compare in a focused, vertical view. This may be helpful if you want to review and analyze multiple records without scrolling horizontally across the entire Listings grid.
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page or Select a study from Study Manager.
  2. Select Listings from the drop-down menu.
  3. Select the Listings type in the left panel of the screen to load the listings in the center grid.
    note
    For details on selecting and viewing listings type, see Choose a listing type and view data
  4. Use Ctrl+click or Shift+click to select multiple rows in the Listings grid.
  5. Right-click the selection and choose Compare Records from the context menu.
    You are taken to an isolated, vertical view of the selected records.
To return to the previous view of the Lisitings interface, click Exit Comparison.
