Review data
The following topics describe how to view discrepancies in a listing, view details, assign and remove flags, view data lineage, and reprocess discrepancies.
- View a single record from data listings
You can access a view of a single record that displays all of the columns on the Listings grid in a vertical manner. This can help you focus on one record at a time while being able to vertically scroll through the information. - Compare records in data listings
You can select up to 100 records within the Listings grid to compare in a focused, vertical view. This may be helpful if you want to review and analyze multiple records without scrolling horizontally across the entire Listings grid. - View discrepancies in the Listings page
- Show all discrepancies on one data item
- View discrepancy details
- Use keyboard shortcuts on listings
- Assign and remove flags
- Show flags assigned to a record
- View data lineage
- View data in InForm or another system
- Reprocess discrepancies that failed to be sent
