Use keyboard shortcuts on listings
After you select a study, a listing, and a record, you can save time and avoid using a mouse by using keyboard shortcuts to access an action or use search fields to find records.
Table 2-2 Keyboard Shortcuts for Listings
Keyboard Shortcut | Description |
Ctrl+Alt+F | Assign a flag to a record: Opens the Assign Flags dialog box for the record you selected in a listing. For more details, see Assign a flag to a record. |
Ctrl+Alt+S | Open the Find field: Opens the Find field at the top of the list of records in a listing. For more details, see Use the Find feature. |
Ctrl+C | Copies column data in one or more rows (Copy Without
Column Headers): Select the column data you want to copy and use
the keyboard shortcut to copy it. To copy adjacent rows in the column,
press the Shift key as you select data items. You see a "Copied
Successfully" message that lists what you copied above the table. Press
Ctrl+V to paste it. For example, you can paste the data into
the Discrepancy text field of the Create Discrepancy dialog box. Or,
paste it into any other application (for example, an Excel spreadsheet
or Notepad).
Note: To copy column data with the header and row number details, select the column data and select Copy With Column Headers from the right-click menu. You cannot use a keyboard shortcut. |
Parent topic: Review data
