Assign application roles to users
If Oracle DMW is installed at your company, follow these instructions.
To ensure security, assign roles based on the minimum privileges needed for users to complete their tasks.For an explanation of application roles, see:
- Log in to Oracle LSH.
- Select User Management from the main menu on the left or from the Navigator drop-down.
- Click Users.
- In the User Maintenance screen, search for the user to whom you want to assign roles.
- Click the user's Update icon. The Update User screen appears.
- In the Roles subtab, click Assign Roles. The Search and Select screen appears.
- Search for all Oracle LSH predefined roles by selecting Search By Role, entering
LSH%, and clicking Go. The system displays all the predefined Oracle LSH application roles in the lower part of the screen. - Select each role you want to assign.
- Click Select. The system adds the roles to the user and the Update User screen appears.
- Enter a justification for assigning each role to the user.
- Click Apply.
Parent topic: Create and set up user accounts
