Set currency behavior for Staging with Audit tables
If a job using Staging with Audit processing does not load, modify, or delete any records, by default the currency is soft-deleted, making it appear that the job never ran, and the currency is not available for that table for downsteam programs. To change this, set this profile to Yes.
Parent topic: Set profiles to determine system behavior
