Set profiles to determine system behavior
- Use character semantics
- Increase the maximum number of nested domains
- Append username to discrepancy text
- Change the study grouping user interface label
- Register root folders for File Watcher watched folders
- Register root folders for File Watcher archive folders
- Set blinding behavior for InForm hidden items
- Make discrepancy categories mandatory
- Make discrepancy actions mandatory
- Date format for conversion to text in unpivot transformations
- Hosted environments
- Set the default number of days of job history to display
- Use custom listing name for the custom listing schema
- Set currency behavior for Staging with Audit tables
- Turn debugging on or off
- Enable UI changes for a clinical data system other than InForm
- Set login-related and other profile values
- Enlarge SAS buffer size
- Study Health Monitor profile values
The Study Health Monitor provides administrators with details on data loads, transformations, validation checks, and discrepancies. It comes with certain data values set. For example, for file loads, transformation, and validation check jobs, Oracle DMW defaults to showing the details for the last day (24 hours), but you can change it.
Parent topic: Cross-study setup outside DMW
