Accept Column Mappings
Use this API to create persistent Auto Maps by accepting the auto generated column transformation mappings.
Name
DME_PUB_XFORM_MAP.AcceptColumnAutoMappings
Signature
PROCEDURE ACCEPTCOLUMNAUTOMAPPINGS
(P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PIO_COLUMNAUTOMAPCOLL IN OUT NOCOPY DME_XFORM_AUTO_MAP_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PIO_COLUMNAUTOMAPCOLL (Mandatory). This is a parameter of table type collection DME_XFORM_AUTO_MAP_COLL of DME_XFORM_AUTO_MAP_TYPE table type. All attributes are required including:
  • COMPANY_ID
  • MAP_ID
  • MAP_VER
  • MAP_ENTITY_ID
  • MAP_ENTITY_VER
  • CANDIDATE_FLAG_RC - with the possible values:
    • $YESNO$YES
    • $YESNO$NO - use this value for auto map suggestions which are applicable to save as real maps.
