Upgrade Transformation Map
Use this API to upgrade the maps defined at model level.
Name
DME_PUB_XFORM_MAP.UpgradeXformMap
Signature
PROCEDURE UPGRADEXFORMMAPS
(P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_XFORMMAPCOMPID (Mandatory). Enter the COMPANY_ID for the transformation map to be upgraded.
  • PI_XFORMMAPOBJID (Mandatory). Enter the OBJ_ID for the transformation map to be upgraded.
  • PI_XFORMMAPOBJVER (Mandatory). Enter the OBJ_VER for the transformation map to be upgraded.
